TiTaNiuM sAMuRai Posted July 15, 2004 Share Posted July 15, 2004 After doing a search, I encountered a heap of questions, a cupful of discussion, and a teaspoon of links. CADViewer is apparently $1000 to $12000 per copy, and is no longer available as a demo. (Tailor Made Software) There is a plugin available for AutoCAD, which imports dwf files to a .dwg, but it is an AutoCAD plugin only. Is anybody aware of a cheap viewer / converter that runs on the Mac? Quote Link to comment
Christiaan Posted August 13, 2004 Share Posted August 13, 2004 Autodesk said in September last year they were porting their DWF Viewer to Mac OS X: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=3557576&linkID=1977925 Quote Link to comment
oldguy Posted August 13, 2004 Share Posted August 13, 2004 DWF is not the greatest format to be converting from. In a pinch, it will do. But most of the "CAD Inteligence" of the "drawing" is gone. Text, for example, is no longer text - it is composed of individual line strokes. Text would have to be re-entered to be editable. AutoCAD blocks are no longer blocks - just the "lines and circles" that made them up. Quote Link to comment
Marietta Posted August 13, 2004 Share Posted August 13, 2004 If you only want to view the file, you can open autocad dwg files in adobe Illustrator, which is pricey enough if you won't use it for anything else. You need to reset the page parameters to show the whole drawing. Of course all the lines show up in the colours the autocad user has used. You could not import directly to any cad program from this, but you can probably make an image file. Quote Link to comment
smoothbase Posted August 14, 2004 Share Posted August 14, 2004 I do not know much about AutoCad although I keep trying to export VW files to it but could you save your files as PDF files in AutoCad as we can do in VectorWorks. That is what I am doing to send files to AutoCad through email one by one (they are splitted in 2,3 or more with Stuffit in order not to block the 10 MB usually available from the Provider) Quote Link to comment
