Andy Haengaertner Posted January 29, 2018 Share Posted January 29, 2018 Hi all, I can get the surface normal of a specific point of a NURBS surface. I'm wondering if there is a way (Node) to get the tangent plane of this surface normal and assign it to a planar 2D object. Does anyone have a tipp or even better a solution for this? Thanks in advance Andy Quote Link to comment
Vectorworks, Inc Employee sbarrett Posted January 29, 2018 Vectorworks, Inc Employee Share Posted January 29, 2018 Hello, There is a node in the Operations folder called the Orient node that allows you to set the z- axis of an object based on a 3D vector. I believe this will work for you based on the parameters you already have. Here is an example file. OrientNode.vwx Quote Link to comment
