I have a question about referenced images. If an image is referenced into a file it normally shows up in the References pane of the Navigation Palette. However in trying to troubleshoot another users forum post I discovered if the referenced image is put into a symbol it does NOT show up the References pane. How do you find its path or update the link for a referenced image in this situation?
It feels like workflow for referenced images is a bit incomplete. Shouldn't clicking on the image within the file show you the path, give you an option to update it and also show you if its out of date/broken in the OIP?
Kevin
