Walls on top of each other
Mikedk64
Not exactly, but you can use the Move command to move each by the same exact distance. The Move command will retain the most recently entered numbers, so this is a pretty fast way to achieve what you're after.  Another way is to select both walls and then drag them together; or better, select them both then Group, then drag, then Ungroup.
Yes you can select both and move both at once.
But it is just not a recommended workflow to use Walls stacked over each other - on a single Layer.
It may cause all kind of problems with generated top plans or or wall auto joining and such.
But no problem if you talk about stacked Walls in different Stories and Layers,
and you want to move all Walls of all Stories at once.
Edited by zoomer
