Duplicate Along Path (without Conversion to Nurbs Object)
twk
Greetings and Happy New Year to you all,
Has anyone figured out how to duplicate an object (locus,symbol) along a 2D path, be it a polyline, polygon?
Developing a plugin to take a symbol object and have it duplicate along the Plugins 2D path (this being a 2D poly path plugin object type).
Have tried the :
def vs.GetPointAndParameterOnNurbsCurveAtGivenLength(inNurbCurve, inPercentOfLength):
    return (BOOLEAN, p, outParam, outIndex)
by converting the 2D path to a nurbs object, running the calc, then copying the /out/ data to the 2D path poly. However just realised the convert to Nurbs command takes into account the orientation of the view. This makes it not feasible for a path-pio object.
Any ideas?
Cheers,
Tui
Why not use Python equivalent of
PointAlongPoly(h: HANDLE; dist: REAL; VAR ptX, ptY, ptZ: REAL; VAR tangentX, tangentY, tangentZ: REAL) : BOOLEAN;
Always a good idea to check file "VWPluginLibraryRoutines.p" in user plugins folder for non documented calls.
