mike46 Posted July 12, 2004 Share Posted July 12, 2004 HI I am having trouble printing to an hp 1220c , a just compleated drawing, rendered in final quality renderworks with several textures none of which is stock but all have been used previously ,printer set for normal the printed result is just a rectangle that looks to be the size of the print area bounding box ?? the drawing will print in wireframe with no difuculty and if I copy to a newly opened drawing set up with the same template it will print rendered untill I start changing views and or lighting . this is the first time this has happened and it repeated 3 times on the same drawing yesterday .. anyone have any ideas (print driver is up to date ) thanks mike Quote Link to comment
Guest Posted July 12, 2004 Share Posted July 12, 2004 After you change the views and lighting and stuff, does the file start to not print correctly again? Quote Link to comment
mike46 Posted July 15, 2004 Author Share Posted July 15, 2004 Hi sorry about not responding sooner been out of the loop for a few days yes after changing view angles ( in perspective ) and lighting (moving or changing light settings ) it will happen again I havn't figured out if it the view or lights yet Thanks Mike Quote Link to comment
mike46 Posted July 17, 2004 Author Share Posted July 17, 2004 nothing major 6.14 mb Quote Link to comment
Guest Posted July 18, 2004 Share Posted July 18, 2004 Try to copy the layers to a new, blank document and see if the problem is duplicated. Quote Link to comment
mike46 Posted July 19, 2004 Author Share Posted July 19, 2004 yes I have done that, it will print fine untill I change views and lighting and its gone again thanks mike Quote Link to comment
Guest Posted July 19, 2004 Share Posted July 19, 2004 Can you print it to any other printer when you notice it won't print? Can you please email the file along with a description of the problem? Quote Link to comment
mike46 Posted July 21, 2004 Author Share Posted July 21, 2004 I tried printing to another printer with the same result I have emailed you the file and an outline of the problem Thanks Quote Link to comment
