Sky Posted January 19, 2018 Share Posted January 19, 2018 I can't seem to change the box size of the detail-callout marker. When I double click it, it goes to the Reshape Tool but it won't reshape the box. Quote Link to comment
0 Boh Posted January 20, 2018 Share Posted January 20, 2018 Try adjusting the text margin. The greater the margin the bigger the box. Quote Link to comment
0 Sky Posted January 22, 2018 Author Share Posted January 22, 2018 I think you misunderstood what a detail-callout marker is. See attachment. Quote Link to comment
0 Kevin McAllister Posted January 22, 2018 Share Posted January 22, 2018 If its a "Detail-Callout" (eg. its linked to a Detail Viewport) edit the crop object of the Detail Viewport and the marker's shape will update automatically. If its a "Detail-Callout Marker" double click on the shape and the Reshape Tool will become active for you to reshape it. Edit it as you would any other polyline. Kevin Quote Link to comment
0 Sky Posted January 22, 2018 Author Share Posted January 22, 2018 Even if I double click on it, there are no resize nodes to available to reshape. I think it is because I used a rounded corner rectangle. I wish they would make rounded rectangles resizeable. Quote Link to comment
0 Kevin McAllister Posted January 22, 2018 Share Posted January 22, 2018 4 hours ago, Sky said: Even if I double click on it, there are no resize nodes to available to reshape. I think it is because I used a rounded corner rectangle. I wish they would make rounded rectangles resizeable. When you look in the mode bar, which mode of the reshape tool is active. If "Move Edges Parallel Mode" is active, the handles disappear for the rounded rectangle geometry. Switch to "Move Polygon Handles Mode" and the reshape handles should reappear. Kevin Quote Link to comment
Sky
5 answers to this question
