taavilooke Posted January 16, 2018 Share Posted January 16, 2018 Hi! I'm using scripts to write data into worksheet database cells with Runscript() function. Every time the worksheet is updated a dialog shows up that asks if the execution of the script should be allowed or blocked. I accidentally clicked on block all. Now the the dialog does not even show up and none of the scripts run in worksheets. How can I re-allow or unblock scripts to be run with Runscript() ? Thanks, Taavi Quote Link to comment
Pat Stanford Posted January 16, 2018 Share Posted January 16, 2018 Vectorworks Preferences, Session Tab, Click the Reset Saved Settings button at the upper right. Make sure you have the "Always do the selected action" choices check box clicked and click OK. This will reset ALL of your Always do choices, so you will have some extra dialogs for a while, but normally you will get all of those reset pretty quickly. Quote Link to comment
taavilooke Posted January 16, 2018 Author Share Posted January 16, 2018 Thanks! That did the trick. Quote Link to comment
