DaveCarr Posted January 15, 2018 Share Posted January 15, 2018 Hi All, I am having an issue with one worksheet not showing the correct data. Here is my example: Worksheet 1 (displays all items correctly), Lists all stage deck items, Purpose, Size, and Height Worksheet 2 (does not display the data correctly), Quantity of Stage Decks needed, Size, and Height Worksheet one gives me 19 objects, 18 4x8 decks and 1 4x4 deck Worksheet two gives me 19 objects, 19 4x8 decks The Criteria on both is set to Type is Stage Deck and all the cells are set to the some record data. My workaround is to manually add the one missing item I've tryed coping the data headers from one to the other and no change. Thank you! Quote Link to comment
michaelk Posted January 15, 2018 Share Posted January 15, 2018 Can you post a file with everything but the stage decks and the worksheets stripped out? Quote Link to comment
DaveCarr Posted January 15, 2018 Author Share Posted January 15, 2018 here you go. Thank you for your time and help in looking at this Dave Carr dcarr worksheet.vwx Quote Link to comment
michaelk Posted January 16, 2018 Share Posted January 16, 2018 Not sure I'm seeing the problem. Maybe I'm looking in the wrong place, but it looks like both worksheet reports are seeing 19 platforms. [Worksheet 1 B6] = 19 = [Worksheet 2 B3] Quote Link to comment
DaveCarr Posted January 16, 2018 Author Share Posted January 16, 2018 Thank you for looking at my file! Yes both worksheets display 19 platforms. The problem is the individual platform counts. Worksheet 1 (furniture) displays 4- 4x8 @2' and 15- 4x8 @ 3' Worksheet 2 (staging) displays 1- 4x4 @ 2', 3- 4x8 @ 2', and 15- 4x8 @ 3' If you look at the drawing worksheet 2 is correct. as far as i can see all the criteria are set the same. I tried copying the criteria from worksheet 2 to worksheet 1 and got the same wrong counting. dcarr worksheet.vwx Quote Link to comment
Pat Stanford Posted January 16, 2018 Share Posted January 16, 2018 Edit the header for Worksheet 1 and turn on the Summarize check box for column C. You will then get 3:15:1 4x8/4x8/4x4. You now need to Summarize each column individually to make sure you get the right information. Quote Link to comment
DaveCarr Posted January 16, 2018 Author Share Posted January 16, 2018 Thank you! Quote Link to comment
