Allen Brown Posted January 12, 2018 Share Posted January 12, 2018 I've got a house design with multiple elevation viewports on sheet layers. Each sheet layer is a different combination of class settings and layers to illustrate several variations. The problem is that sometimes, not all times, the sheet viewports "forget" the override settings and revert to the current class settings. Huge waste of time to go back and change each material back to the override setting. Any thought on why this is happening? Quote Link to comment
Andy Broomell Posted January 12, 2018 Share Posted January 12, 2018 Are you ever using the Eyedropper tool on Viewports? Just one thought... Quote Link to comment
Allen Brown Posted January 12, 2018 Author Share Posted January 12, 2018 No, I'll give it a try. Would save time changing back to the override settings. Still can't figure out why the settings are being lost.. Quote Link to comment
Andy Broomell Posted January 12, 2018 Share Posted January 12, 2018 4 minutes ago, Allen Brown said: No, I'll give it a try. Would save time changing back to the override settings. Still can't figure out why the settings are being lost.. Oh that's actually a good idea! I was actually wondering whether you had perhaps been using the Eyedropper to transfer some other properties and were inadvertently also transferring class override settings. Not sure what else could be causing it... Good luck! Quote Link to comment
