Allen Brown
Sheet viewport class overrides revert to design
I've got a house design with multiple elevation viewports on sheet layers. Each sheet layer is a different combination of class settings and layers to illustrate several variations. The problem is that sometimes, not all times, the sheet viewports "forget" the override settings and revert to the current class settings. Huge waste of time to go back and change each material back to the override setting. Any thought on why this is happening?
No, I'll give it a try. Would save time changing back to the override settings. Still can't figure out why the settings are being lost..
Oh that's actually a good idea! I was actually wondering whether you had perhaps been using the Eyedropper to transfer some other properties and were inadvertently also transferring class override settings.
Not sure what else could be causing it... Good luck!
  • 7150 Riverwood Drive
  • Columbia, Maryland 21046, USA
  • Contact Us | 410.290.5114
  • © 2018 Vectorworks, Inc. All rights reserved.
  • Vectorworks, Inc. is part of the Nemetschek Group.
