Design Viewport not showing in Sheet Viewport
RonaldHH
Hello All,
Here is my issue...I set up section viewports to be applied to a design layer for annotation. From there, I created another viewport for the drawing to be placed on a sheet. The viewport on the sheet does not show the design viewport in a handful of instances, but in some, it works fine. I have checked visibilities from classes, layers, ect.
I have tried using the eyedropper tool to copy attributes from the viewports that are showing, to the ones that are not, but no luck. I am at a loss! Any ideas?
4 answers to this question
@RonaldHHHi, Are all your design layers the same scale?
Normally I would create a section viewport and place it on a sheet layer then annotate in the annotations layer of that viewport.
If sometimes i want to bring the viewport back to a design layer i will convert to lines and copy paste to design layer and scale it up by 100 (Metric and design layer set to 1:100)
HTH
Thanks Alan,
yes, all the layers are at the same scale. I set up the drawing up this way so that I could put all sections on the same layer, and be able to add linework detail easily. I can then transfer detail from section to the other without having to jump between sheet viewports. It saved me loads of time, except for this last hangup!
Attached are a couple screenshots to show the issue...
Sheet viewport enforce "unified view" they must all be in the same view orientation as well as scale.
If you have a 2D design layer viewport showing in a Section viewport you can't make a sheet viewport that shows that. My workaround is to stack up viewports on the sheet. Align them carefully and everything is fine.
