Emily L Posted January 11, 2018 Share Posted January 11, 2018 Here is my script for auto-generate the dimension to the object info. However, it only works for the objects that are totally 0, 90, and 180 degrees, or the dimensions are off due to the angle. Is there anyone who can help me with my script? Thanks very much. ------------------------------------------------------------------------------------------------------------------------------------------------ PROCEDURE InputData3D; CONST RECD = 'PanelSizes'; VAR h:HANDLE; W,T,D:REAL; W1,T1,D1:STRING; BEGIN h:=FSActLayer; REPEAT Get3DInfo(h, T, W, D); W1:=Num2Strf(W); T1:=Num2Strf(T); D1:=Num2Strf(D); SetRecord(h,RECD); SetRField(h,RECD,'Width',W1); SetRField(h,RECD,'Height',T1); SetRField(h,RECD,'Depth',D1); h:=NextSobj(h); UNTIL(h=NIL) END; RUN(InputData3D); Quote Link to comment
MullinRJ Posted January 11, 2018 Share Posted January 11, 2018 (edited) Hi Emily, To get an "orthogonal" 3D size, you must first unrotate a 3D object before using Get3DInfo(). I modified your script to do just that. I also merged your Num2StrF() statements into the SetRField() statements to shorten the script a little. PROCEDURE InputData3D; { Get 3D_Size and attach or modify a "PanelSizes" record with the info. } { 11 Jan 2018 - Emily L. - Original script works for unrotated 3D objects only. } { 11 Jan 2018 - R.Mullin - Unrotate objects before measurement, then re-rotate them. } CONST RECD = 'PanelSizes'; VAR h :HANDLE; W, T, D :REAL; Xcen, Ycen, Zcen :REAL; xRot, yRot, zRot :REAL; isMirrored :BOOLEAN; BEGIN h := FSActLayer; REPEAT if Get3DOrientation(h, xRot, yRot, zRot, isMirrored) then begin Get3DCntr(h, Xcen, Ycen, Zcen); { get 3D center } { unrotate 3D object } Set3DRot(h, 0, 0, -zRot, Xcen, Ycen, Zcen); Set3DRot(h, 0, -yRot, 0, Xcen, Ycen, Zcen); Set3DRot(h, -xRot, 0, 0, Xcen, Ycen, Zcen); Get3DInfo(h, T, W, D); { get 3D size } { re-rotate 3D object } Set3DRot(h, xRot, 0, 0, Xcen, Ycen, Zcen); Set3DRot(h, 0, yRot, 0, Xcen, Ycen, Zcen); Set3DRot(H, 0, 0, zRot, Xcen, Ycen, Zcen); { store data in attached record. } SetRecord(h, RECD); SetRField(h, RECD, 'Width', Num2Strf(W)); SetRField(h, RECD, 'Height', Num2Strf(T)); SetRField(h, RECD, 'Depth', Num2Strf(D)); end; { if Get3DOrientation } h := NextSObj(h); UNTIL(h=NIL) END; RUN(InputData3D); HTH, Raymond Edited January 11, 2018 by MullinRJ Quote Link to comment
