Robert Janiak Posted December 29, 2017 Share Posted December 29, 2017 Video screen bug Quote Link to comment
Guest Beckstorm Posted January 2, 2018 Share Posted January 2, 2018 @Robert Janiak Could you send us your file so we can look at this issue? Quote Link to comment
Robert Janiak Posted January 2, 2018 Author Share Posted January 2, 2018 (edited) 43 minutes ago, BrandonSPP said: @Robert Janiak Could you send us your file so we can look at this issue? Hi I prepared test file again. I have the same bug. Top screen is a extruded rectangle with texture. Bottom screen is a Video Screen Plugin. I attached zip included files: .vwx .v3s texture folder and print screen image. I used Send to Vision... command. VW version 2018 SP2 (Build 401138) (64-Bit) PL Vision version 23.0.2.405396 If you need i can do more tests and send you at priv or mail. Please give me info if you known this problem. Video bug.zip Edited January 2, 2018 by Robert Janiak Quote Link to comment
Guest Beckstorm Posted January 2, 2018 Share Posted January 2, 2018 @Robert Janiak Thanks for your help we will look into this. Quote Link to comment
Robert Janiak Posted January 4, 2018 Author Share Posted January 4, 2018 Hi, please confirm if is a bug or my setup problem. Now, Vision is useless for me and I am very frustrating. Still photo rendering quality is awful. Vision please back to ESP Vision 2.3 quality. Quote Link to comment
Guest Beckstorm Posted January 4, 2018 Share Posted January 4, 2018 Looks like this is a bug, I have sent it over to the engineers to have a closer look and confirm. Quote Link to comment
Robert Janiak Posted January 4, 2018 Author Share Posted January 4, 2018 Ok. I am waiting. Quote Link to comment
Guest Beckstorm Posted January 5, 2018 Share Posted January 5, 2018 So we have confirmed this is a bug and the engineers are working on it. Quote Link to comment
Robert Janiak Posted January 5, 2018 Author Share Posted January 5, 2018 7 minutes ago, BrandonSPP said: So we have confirmed this is a bug and the engineers are working on it. Thanx for info. By the way, screen has emision effect if video source is video file. If source is still image e.g .jpg screen is dark without emision shader. Please add still image as source file for screen. Quote Link to comment
Guest Beckstorm Posted January 5, 2018 Share Posted January 5, 2018 Good point, I will pass that along as well and see what they can do. Quote Link to comment
Vectorworks, Inc Employee bbudzon Posted January 5, 2018 Vectorworks, Inc Employee Share Posted January 5, 2018 This bug is in VW 2018 SP2, not Vision 2018 SP2. We will try to figure out if this broke in a VW SP and why. Fortunately, there is a fairly easy and straight forward work around. Simply don't assign video from VW until this bug is resolved or use an older VW releases. I would recommend using VW 2018 SP2 to export your video screen with static images for the texture, such as color bars or the VW logo. This will bring the screen over as one mesh shape. This mesh shape can have its video assigned once in Vision and things should work fine. I wanted to get you an updated file that had only one mesh shape for the screen, but it's harder to remove a video file attached to a screen that I would have thought. We will discuss this internally and try to make that workflow easier. For this reason, I'd recommend you try to follow my steps above so you don't end up with multiple mesh shapes for your screen in your file. That being said, if you don't mind the extra mesh shapes, I've attached a zip that contains an updated v3s with video working for all mesh shapes. I hope your video screen issues are resolved for the mean time and that you enjoy the new features in Vision 2018 SP2! Video bug.zip Quote Link to comment
Vectorworks, Inc Employee Edward Joseph Posted January 5, 2018 Vectorworks, Inc Employee Share Posted January 5, 2018 It should also be noted that changing the texture to x.cap from PC: C:/Program Files/Common Files/Vectorworks 2018/textures/app/ or /MacHD/Library/Application Support/Vectorworks 2017/textures/app/ on mac, initiates the capture device dialog - for those who are intending to use capture devices. Quote Link to comment
Robert Janiak Posted January 6, 2018 Author Share Posted January 6, 2018 @bbudzon@Edward Joseph Guys are you amazing. That temporary solution is great. Even cam works fine. What do you thing about Spout integration? Resolume has Spout sender. Spout suport Virtualcam and NDI. I used this with old Vision successfully. http://spout.zeal.co/ Quote Link to comment
