Wesley Burrows Posted January 8, 2018 Share Posted January 8, 2018 Does anyone have a 3D drawing of these? I reached out to my contact @ Atomic Design on Friday but haven't heard back yet. Sidebar. It would be rad if the Atomic stuff was included in our libraries :-) Quote Link to comment
CETLV Posted January 8, 2018 Share Posted January 8, 2018 I made this conversion in DWG, you can import it and it may work ok. Note: I work in 1:1 all the time to make cross platforming easier, so you may have to scale it. Its an upgrade since anything from atomic will be all wireframe with no meshes anyways. hive 3d solid.dwg Quote Link to comment
Wesley Burrows Posted January 8, 2018 Author Share Posted January 8, 2018 7 minutes ago, CETLV said: I made this conversion in DWG, you can import it and it may work ok. Note: I work in 1:1 all the time to make cross platforming easier, so you may have to scale it. Its an upgrade since anything from atomic will be all wireframe with no meshes anyways. hive 3d solid.dwg This is great! Thank you! Quote Link to comment
Mickey Posted January 22, 2018 Share Posted January 22, 2018 It's unfortunate for them. I have received a few files over the years direct from my sales rep at Atomic, and the file format is different for each tile I've used. I usually end up redrawing over their object so I have native VW geometry, and not imported DWG messes. Quote Link to comment
CETLV Posted January 22, 2018 Share Posted January 22, 2018 My experience with atomic has been great. I get most of the new ones as soon as they are made public. However I always have to clean them up and make the extrudes work for my workflow here at my job. They make them all in other programs, and there is always issues importing into autocad. but it can be done. Quote Link to comment
