I'll post this as a separate thread since this has nothing to do with Mac-related graphics card issues discussed in another thread.
We're encountering pretty maddening issues with screen updates in VW 2018. Please see the attached images. In a nutshell:
1) A door is moved to another location in a wall.
2) You can't see that the door has moved to the new location. It still appears in the original place.
3) If you do a mouseover on the new location, you can see the outline of the door. You can still see the door in the old location, as well.
4) When you zoom in/out a bit, the screen is updated properly and the old door disappears and the new one appears.
We've encountered this problem with walls, too - sometimes when you draw a wall, it's not visible before you zoom in/out.
I've tried every possible setting in the graphics options - no difference.
Sometimes the issue goes away for a while and sometimes it appears again, which makes it even harder to track.
We can replicate this on all different pc setups, so it's not likely to be a graphics card problem. We use cards from Quadros to GF 1050Ti's to laptop cards. No difference. We've tried to update all drivers on all machines. No help there either.
From here on, we will adopt a policy of updating to a newer VW version only after the 5th service pack has been published. It's simply not possible to update before since the initial releases are, politely put, betas.
For 2019, please fix doors, windows, stairs, overall quality and stability. I'll send you flowers and chocolate to HQ if you do that.
JMR
Hi all,
3 answers to this question
