Eb Madry Posted January 4, 2018 Share Posted January 4, 2018 Does anyone know if it is possible to link the fixture mode in Vectorworks to the Profile of a fixture in Lightwright 6? Quote Link to comment
Vectorworks, Inc Employee Rob Books Posted January 5, 2018 Vectorworks, Inc Employee Share Posted January 5, 2018 For VW2018, the Fixture mode is populated from the Fixture ID in the Light Info Record, so if you map the profile to that field, it should auto-populate. For VW2017, Fixture mode comes from the Inst Type Field. But you need to ensure that you have the mode name correct or it will not be found. Quote Link to comment
Eb Madry Posted January 5, 2018 Author Share Posted January 5, 2018 Hi Rob, The issue is I don't seem to see the profile body column in Lightwright as an option. I want the profile of the fixture to appear on in my label legend, but can't seem to get it there. I am attaching two pictures. I want to make sure I am using the profile feature in Lightwright so I can use the address map and auto addressing features, but I want it to appear on my plot as well. I can use the a user column but that doesn't relate to the profile which is the issue. Quote Link to comment
Vectorworks, Inc Employee Rob Books Posted January 5, 2018 Vectorworks, Inc Employee Share Posted January 5, 2018 I just looked in the VW2018 lightwrite exchange tab (File>Document Settings>Spotlgiht Preferences), and Fixture mode is one of the data fields that can be exchanged. Not sure how to map that to Profile, as I have not had time to play with Lightwrite for quite some time. @John McKernonmight be able to help with that side of it. Quote Link to comment
Vectorworks, Inc Employee klinzey Posted January 8, 2018 Vectorworks, Inc Employee Share Posted January 8, 2018 This is going to be a question for John McKernon@Lightwright. There appear to be quite a few fields that you can export from LW that are not in the available fields for the data exchange list. Note that setting the Vectorworks fixture mode to the Lightwright profile will not allow Vectorworks to properly recognize the fixture properly so the Gobo and color wheel information in Vectorworks will be incorrect. I recommend using a custom user filed in Vectorworks to store the LW profile setting. Quote Link to comment
Lightwright Posted January 8, 2018 Share Posted January 8, 2018 It's not helpful to share fixture modes, because Vectorworks and Lightwright use different databases for their fixture profile information, and the text used to describe the mode is different in each. Same problem between Lightwright and Eos - different profile databases. Lightwright doesn't deal with it at all, Eos handles it by showing you the Lightwright profile/mode and lets you then select the appropriate match from the Eos data. There's no similar feature to do that in Vectorworks as far as I know. Quote Link to comment
Eb Madry Posted January 8, 2018 Author Share Posted January 8, 2018 Just now, Lightwright said: It's not helpful to share fixture modes, because Vectorworks and Lightwright use different databases for their fixture profile information, and the text used to describe the mode is different in each. Same problem between Lightwright and Eos - different profile databases. Lightwright doesn't deal with it at all, Eos handles it by showing you the Lightwright profile/mode and lets you then select the appropriate match from the Eos data. There's no similar feature to do that in Vectorworks as far as I know. That makes sense. But is it possible to map the LW profile to a user field? I want it to show on my paperwork and plot, but don't see it as an option in body columns. Quote Link to comment
