  • 1
tsw
Referenced files not displaying in Black and White Only
In Vectorworks 2018 (Windows 7 64-bit), if you select "Black and White Only" under Advanced Properties of a referenced Design Layer Viewport then create a Sheet Layer Viewport, Hidden Line mode will render using the original colors of the referenced file. This is different than Vectorworks 2017 and (I'm assuming) a bug. Is this a known issue? Any workarounds? I don't want to check "Black and White Only" on my Sheet Layer VP since I have other objects and callouts I'd like to show in grayscale.
See attached file for an example.
BW Viewport Example Files.zip
1 answer to this question
I'm see the black and white option pop in and out for referenced design layer viewports.
