reGenerate Design
Grey box in openGL plant object 3d preview instead of 3d plant/image prop
Hello there,
I am hoping that someone might be able to help me with a Vectorworks 2015 3D rendering issue that I'm experiencing. When I try to view plant objects in 3D, I only see a grey box in the openGL 3D preview pane. I've attached a file that has a single plant object in it. I would expect that I should see the 3D graphic or image prop for this plant object instead of a grey box.
I have set the render mode to be openGL in VW preferences already.
Thanks so much for any help on this.
Adrian
VW 2015 3D plant object issue.vwx
Looks fine here.
Do you have deactivated "use Textures" in OpenGL options ?
(If I do this it will look as you describe)
Ahm, do you have Renderworks ?
I think this is needed for showing transparencies.
It came free and included after VW 2016 or 2017.
Or not properly installed (or hidden or not working because of a current bug ?)
I think unavailable RW package makes use Texture setting grayed out,
which it is not for me.
Or in the worst case a too weak GPU, or VW not assigned to the faster card
on notebooks by default (to save energy)
