  • 5
David Poiron
Wall Style Total R-Value
6 answers to this question
Instead of just totaling up the nominal R-values of the wall assembly, what would be more useful is to calculate the effective or real R-value of the Wall assembly which takes into account the effects of thermal bridging based on the construction type of the wall.
The calculated real or effective R-value can be much lower than the nominal R-value.
Edited by rDesign
Or could be higher as they don't take in to account the air skin in the outsides of the walls or any internal cavities.
Totally.  A total of each components R-value is a wasted exercise and would not be accepted by most if not all jurisdictions.  Here in New Brunswick we use Canada's National Building Code and it requires us to show the effective R-value for all exterior assemblies in a Part-9 building.  Having VW handle the calcs would be helpful.  It is always good though to know how to make the calcs to ensure the answer is correct.  Is it possible that the answer could be different depending on where you are?  I would think it should be the same.
Gets my vote.
The ability in Vectorworks to calculate the effective R-value of parallel items within components would be great. However, in my example the lambda of component 4 is calculated to take this into account and so the total would be correct. I'm just asking for the total to be displayed in this location. It would be nice to have air films included in some way too but I consider these to be a "fudge-factor" to review in case I am very close to the required values.
I see what your saying @David PoironI wouldn't want to take away from your wish, lets just add to it.  So a couple or a few results could be posted.
1...a simple sum of all present R-Values
2...an Effective R-Value of the wall assembly.
Number 2 would be useful in putting together a worksheet showing the Effective R-Values for permit purposes.
Edited by Markvl
Agree with @Markvl no need to delay. Energy tools are likely to stay useful but not valuable for a few versions yet so best get on with useful tweaks. While care is taken on the more valuable code compliance.
