Squirrely7 Posted December 13, 2017 Share Posted December 13, 2017 I draw truss objects that I downloaded from the Christie website. I went in and deleted the 2d object leaving only the 3d. Once I draw the rig, how do I use VW to count the truss for me? Is this under export? Thanks Quote Link to comment
markdd Posted December 14, 2017 Share Posted December 14, 2017 You could make a worksheet which should be able to do that for you. As long as the truss record is still held by the individual truss symbol, you should have no problem creating a worksheet based on that. If no truss record is attached to the symbol then you could just do a symbol count instead. ( I don't have Christie Truss, but as this should work on any symbol or any object with the Truss record attached.) Quote Link to comment
Squirrely7 Posted December 14, 2017 Author Share Posted December 14, 2017 Thanks. One more question, is there a way to get it to spit out totals by symbol rather than a single line item per symbol? It looks like your example does what I want, but I can only get single counts. My work around is to cut and paste it into excel and use the cell count feature. A little ghetto but it works for now. File path: Spotlight -report --create report ---List All (symbols) Quote Link to comment
Pat Stanford Posted December 15, 2017 Share Posted December 15, 2017 IN VW2017, you would select a row in the database and then drag the SUM tile to the column header. Drag a second (third, etc.) SUM tile into any column that you do not want to be summed (summarized). In 2018 this is handled in the database header row cell pull down menus. Select Summarize for the correct column. Then select Sum Values for the columns you want totaled. 1 Quote Link to comment
Squirrely7 Posted December 21, 2017 Author Share Posted December 21, 2017 Thanks again. I'll give it try tomorrow. Quote Link to comment
C. Andrew Dunning Posted July 17, 2019 Share Posted July 17, 2019 On 12/15/2017 at 9:41 AM, Pat Stanford said: In 2018 this is handled in the database header row cell pull down menus. Select Summarize for the correct column. Then select Sum Values for the columns you want totaled. I've got a Worksheet listing instances of a given PIO, summarized by a selected field. What is the syntax for displaying the count for each summary? Quote Link to comment
C. Andrew Dunning Posted July 17, 2019 Share Posted July 17, 2019 4 minutes ago, Pat Stanford said: =Count Thanks. I had the right word but wrong syntax... Quote Link to comment
Pat Stanford Posted July 17, 2019 Share Posted July 17, 2019 You are welcome. I figured the short version answer would be enough for you. 😉 Quote Link to comment
C. Andrew Dunning Posted July 17, 2019 Share Posted July 17, 2019 16 minutes ago, Pat Stanford said: You are welcome. I figured the short version answer would be enough for you. 😉 Wow...a height joke... ;-) Quote Link to comment
Pat Stanford Posted July 17, 2019 Share Posted July 17, 2019 Unintentional, but still funny now that I think about it. Hope you are well. 1 Quote Link to comment
