Sean R. Posted December 13, 2017 Share Posted December 13, 2017 Hello, I have been using vectorworks for 1 year and am new to vectorscripts. I would like to make a script that sets the default settings of the Stake tool. I read some other posts about a similar topic but am not able to understand the solution. I can't seem to properly call up the record and change the field value for the tool and I can figure out how to find the record for the tool to make sure I trying to edit the right record. Anyone know how to change the stake tool and have a working script or a sample one on how to do this? Thanks Quote Link to comment
Hippocode Posted December 13, 2017 Share Posted December 13, 2017 Normaly you can't modify any tool defaults with VS. What you can do is modify the default parametric record used in creating a new object. The parametric record is unique and can be retrieved with the unique name of the object. You can get the handle with GetNamedObject or some similar function taking a string. The normal Get/Set record field functions will work on this handle. Quote Link to comment
Sean R. Posted December 18, 2017 Author Share Posted December 18, 2017 Do you have an example of this for the current stake tool? Quote Link to comment
Hippocode Posted December 18, 2017 Share Posted December 18, 2017 This should get you started. Modify the <> wrappers to the exact name, recordname and value you want to modify. Note that you might need to native object name which can differ from the visual localised objectname. Procedure EditRecordFormat; VAR ObjectName :String; RecordFormat: Handle; ObjectType: Integer; BEGIN ObjectName := '<ObjectName>'; RecordFormat := NIL; RecordFormat := GetObject(ObjectName); IF (RecordFormat <> NIL) THEN BEGIN ObjectType := GetTypeN(RecordFormat); IF (ObjectType = 47) THEN BEGIN SetRField(RecordFormat, ObjectName, '<FieldName>','<FieldValue>'); END; END; END; RUN(EditRecordFormat); Quote Link to comment
