Bruce Kieffer Posted December 13, 2017 Share Posted December 13, 2017 There's lots of free space in the OIP shape section. Please add a Notes field where text can be entered to notate an object. Quote Link to comment
0 Matt Overton Posted December 15, 2017 Share Posted December 15, 2017 How would this translate to printed output? If I need to leave a note for the team I probably need to tell the builders. At the same time really see if value in being able to see those notes by touching the object in any view. Sorry a bugbear of mine is how much information Vectorworks BIM requires to work that doesn’t translate to deliverables. Quote Link to comment
0 Bruce Kieffer Posted December 15, 2017 Author Share Posted December 15, 2017 I'm not thinking of this as a note for anyone other than me. Some place for me to notate info about the Vectorworks object. Quote Link to comment
0 Kevin McAllister Posted December 16, 2017 Share Posted December 16, 2017 I assumed these were working notes for the person working in the file. I could see using it as a place to remind myself of a material, a dimension, something to check, a date something was created, where an object was copied from, what an object started from or any number of other things. In a collaborative process the note field could contain something as simple as who modelled it. Ideally every object in VW would have this field. It could be useful to see the note by hovering over an object, like a tool tip. I don't think this is intended to be something that translates into part of a finished drawing. Kevin Quote Link to comment
0 Bruce Kieffer Posted December 16, 2017 Author Share Posted December 16, 2017 11 hours ago, Kevin McAllister said: I assumed these were working notes for the person working in the file. I could see using it as a place to remind myself of a material, a dimension, something to check, a date something was created, where an object was copied from, what an object started from or any number of other things. In a collaborative process the note field could contain something as simple as who modelled it. Ideally every object in VW would have this field. It could be useful to see the note by hovering over an object, like a tool tip. I don't think this is intended to be something that translates into part of a finished drawing. Kevin Exactly! And funny you should mention the idea of object info hover "tool tip." I was imagining that too the other day. Like a mini OIP. I think it would need to evoked with a keyboard command rather than hover, and have user configurable info that could be shown and whether it is on or off, and it needs to be small. Since I've been using spit screen I find I want an OIP in each screen, and this "info" functionality would solve that. Quote Link to comment
Bruce Kieffer
4 answers to this question
