If I'm using multiple profiles to create an Extrude Along Path the result is one extruded object on the active Class, with the attributes of that Class.
What I'd prefer is multiple extruded objects using the same Class as the profile objects that they came from and using the same attributes of those profile objects.
From there it's just one step to a Auto-hybrid with all objects using the desired attributes.
As it currently stands we have to:
1. Create a separate Extrude Along Path for each profile, copying and pasting the path object for each one
Christiaan
2. Then we have to change the Class of each EAP
3. Then select them all to create an Auto-hybrid
0 answers to this question
