I've got a problem here that I can't figure out. It seems that I cannot "summarize" columns in my takeoff worksheet. Having ver. 2018, in the database row I should be able to select a column header and press the arrow key to the right and the dialog box pops up. If I select sum values the column should compress and show an overall value. It just won't do it.
Bug?
You will see in the pick that under column D I have an ascending symbol a plus sign and a 1 in that little box yet the columns below do not sum up.
Bug?
Edited by MarkvlShare this post
