- 17
Spotlight improvements to Numbering instruments
Asked by
Sebastiaan
Asked by
Sebastiaan
7150 Riverwood Drive, Columbia, Maryland 21046, USA | Contact Us: 410-290-5114
© 2018 Vectorworks, Inc. All Rights Reserved. Vectorworks, Inc. is part of the Nemetschek Group.
I would like to propose the following improvements to numbering instruments:
- The number instruments settings window should have the ability to save and recal setting made in it.
For instance saving a setting for DMX numbering. And saving a setting for Circuit numbering.
- The ability to link the auto increment setting of two fields in de number instrument window.
For instance when assigning multi cable channels to instruments. I set the circuit name to start at ‘A’ and the circuit number to start at ‘1’. When numbering the circuit name will not increment until the circuit number has reached it’s set maximum, for instance 6. So when I reach A-6, I would automatically continue at B-1. And so on.
-Also when manually nummering instruments, each number should appear directly after each click. Right now all the numbers do not appear until you click on an empty piece of the drawing. This should be instant.
- And it would also be great to have the ability to adjust which fields are 'eligible' for use in the Number Instruments tool - i.e. it would be nice to be able to use it to directly label Purpose fields in order, without having to dump the labels into another field and then do a find/modify...
