Christiaan Posted December 7, 2017 Share Posted December 7, 2017 I find there's a balance to be found between the number of Levels in a model and just offsetting from existing Levels. I'm curious to know if anybody has settled on a set of rules or principles for setting up additional Levels vs using offsets? The current file I'm working, for instance, has the following levels. Quote Link to comment
Guest Wes Gardner Posted December 18, 2017 Share Posted December 18, 2017 Hi Christiaan, Yours is a good list...I'm sure you'll agree that alot of set-up is project-dependent. I WOULD want at least something that speaks to the "Top of Footing"....I then use an offset to get a "bottom of footing" to define the thickness of the footing. Wes Quote Link to comment
