After having a few problems with the Roof and Roof Face objects, it seems to me that the height datum and Roof Axis Line (slope line) should be two separate controls, instead of one.
An example of why—as I found out in this exercise—is that the slope line can be used to control the edge of a component that is not associated with a set of walls:
But if you move the slope line and think you're simply moving the edge of the component then you're sorely mistaken, because moving the slope line will change the height of your entire roof, requiring you to then manually readjust it.
Christiaan
https://forum.vectorworks.net/index.php?/topic/53406-how-do-you-make-top-roof-component-overhang-the-fascia/#comment-268301
Edited by ChristiaanLink to comment
1 answer to this question
