landscpe printing
Alex U
Issues with printing landscape A1 to A3 docs at 50% after installing High Sierra and SP4. The page is set up as normal but the print or pdf reverts from landscape to portrait despite the page beng set to 1:1 ratio etc. This basicall means that any landscape file only prints portrait. Any clues how to fill this?
10 answers to this question
Do you happen to have an Epson printer? I had many reports of this from that brand after the High Sierra update. If you attempt to print landscape at the same size from another application, does the same issue occur?
In most cases, these issues were corrected by manually installing the latest printer drivers from the printer manufacturer.
The problem is OS High Sierra.
Good old Apple rubbish updates strike again!
Pages is affected too.
I have solved the issue by going into system preferences and deleting the printers then reinstalling the drivers and adding back in. It is a pain but it has worked.
