L+K Posted June 23, 2004 Share Posted June 23, 2004 VW 10.5.x, PC, XP Pro We were working with PDF settings & now we can only open 1 file at a time only by double-clicking on the file, if you open another file VW crashes. If we open VW and try to open the file the error message comes up then VW crashes. This makes it a little difficult to work efficiently. Any suggestions on a cause??? or better yet a fix! Quote Link to comment
Guest Posted June 23, 2004 Share Posted June 23, 2004 It's a known issue between Adobe and VectorWorks. VW 10.5.0 should cure the problem. You may want to double check to make sure you are definately using VW 10.5.0 and even update those to 10.5.1. If you can't get it to work, when you open a VW document - change the printer from Adobe PDF to something else. You'll then be able to open a second file. [ 06-23-2004, 11:15 AM: Message edited by: Katie ] Quote Link to comment
L+K Posted June 23, 2004 Author Share Posted June 23, 2004 That worked! Thanks! Quote Link to comment
