• Announcements
    • JimW
      How to use the Wishlist   09/21/2016
      Create a new post here, stating both what you would like to see added to Vectorworks or it's supporting systems and web pages and why you would like that change made. If you see an idea you like, press the ^ arrow to the left of the post's title to promote that idea or feel free to comment on that idea with any additional considerations or concerns you may have.
  • 4
Kaare Baekgaard
Stopping a rendering
How is this still an issue?
I am waiting for VW to stop re-rendering a scene for the umpteenth time, because I accidentally made a slight swipe on the mouse, as the rendering started, and that is a very bad thing.
I have hit escape and command-period a few dozen times and yelled at the computer, but to no avail. I would force-quit if it wasn't for the fact, that I have failed to save for a while, and the auto-saves never ever regenerate objects with complex histories, and for some reason I still cannot deselect the completely unnecessary compression of autosaves.
So I wish I could just stop those goddang renderings, I don't think it is too much to ask.
Ahrrr.
9 answers to this question
Agreed that there should never be an instance where you can't stop a render. It's gotten better over the years, but it still happens.
But to double check, if you're doing a lot of rendering, have you tried rendering with sheet layer viewports?
I'm pretty sure this is related to the math functions of rendering being handled by a single core. Because that calculation is single core there's no way to break out of it. Once everything is moved to multicore I believe this will be solved.
Kevin
Yes, I do both types. But for large and heavy jobs viewports do not consistently render the scene correctly.
Interesting. How so?
I am actually experiencing this problem with sheet layer viewports right now. Even for light renders 2018 is failing with some regularity in Viewport renders. not very complex scenes, with relatively few light sources.
There are three or four types of errors, but knowing that they are there, I don't go looking for them, so I cannot give a complete writeup.
Two different errors in lighting, black background instead of white, the new shadowcatcher texture does not work in viewports and alpha channel fail – are among them
Edited by Kaare Baekgaard
I can sometimes fix this issue by changing the render mode from 'final quality renderworks' to 'custom renderworks' with the same settings.
Yes, thanks. But how irritating to have to fiddle around instead of making progress and getting the job done.
