Patrick Winkler
ConvertToPolygon() - Resolution
I'm not sure which resoltuion to use for ConvertToPolygon().  http://developer.vectorworks.net/index.php/VS:ConvertToPolygon
<50 is obvious to less.
90 and 100 convert a cirlce to 32pt polys and 150 to 64 pt polys.
In this case 90 should be enough as even in renderworks my eyes can't spot a difference to the higher resolutions.
It would be good to know how the resoltution effects the outcome (why do 90, 100 create the same ) and if there is a maximum value.
5a1d23c5ef017_Bildschirmfoto2017-11-28um09_50_59.thumb.png.c98411b4b790fee8cedd0c8d4aea51fa.png
regards, Patrick
Patrick,
   The resolution number is not linear, but makes transitions at powers of 2. The number of sides generated is also a power of 2.
Conversion resolutions of:
0-7 yield 2 sides;
8-15 yield 4 sides;
16-31 yield 8 sides;
32-63 yield 16 sides;
etc., up to 512 which yields 256 sides. Values higher than 512 all yield 256 sides.
HTH,
Raymond
I don't mind at all. Add away. One thing to keep in mind, this conversion ratio works for a single curve segment, as a Circle, Arc, or Oval. For complex (multiple) curves, like those existing in a Polyline or Rounded Rectangle, the number of segments created using this relation is per curve.
Raymond
