ida
VW 2018 Project sharing
Hi,
Anybody using VW 2018 project sharing?
We have had quite a lot of problems using it.
1. The object base checkout seems not to work properly and we had to be very strict on only using layer checkout.
Often we could do changes to objects another person had checked out.
2. One person in committing but the changes are not saved to the project file. The person doing the changes do a commit and it even comes up as a change in the other persons working file, both as an update on the refresh button and in the history of the project sharing menu. But the change is just not there. We had to do a projectile from the person that had done the plan changes and the changes done by the other person on the facades just had to be discharged. This is a very annoying problem. It seems that the connection to the project file is suddenly just lost, or is working half way. Some stuff is committed other things not.
We are updating to SP 2 today and hope that these issues will be improved.
Any others having the same problem?
Have updated to SP2 and we still have problems with changes not being committed properly.
Some changes are committed like updating saved views, but adding a new layer are not committed.
We have now changed the settings in the working file that  was the problem in the project sharing menu on "Settings" to have ticked on "Safe Save"
It now seems to work.
If others have the same problem this can be the issue.
Anybody else using project sharing in 2018?
The unstable issue on object based check out seems to continue......
Active shared projects are one of the reasons I've kept our office on 2017.  I'm going to keep it that way for a while I think, seeing this.
If you dont use project sharing and just a regular vwx file it works fine :)
And now we hope no more problems with partial committing.
Hah, if I don't open the software it can't crash...
We have experienced the same issues with some commits not saving. I don't know if this has to do with the SMB/AFP file sharing protocol for macs.
Working offline does not work properly anymore as you cannot just have the layers checked out but also all the objects on that layer checked out which is difficult/time consuming to filter out.
Could you please clarify the problem you are experiencing? Also what version of Vectorworks are you using?
Once you check out a layer, you own all the objects on that layer. You do not need to check out individual objects on that layer. As far a filtering out objects, have you used the "Custom Check Out..." menu command under the Tools menu?
Thanks,
Tolu
Vectorworks 2018 SP2 (Build 401138) (64-Bit)
Fundamentals, Architect, Renderworks
Issues:
When saving and committing a lot of changes, sometimes only some items are committed on to the server.
Could it be possible that during the commit, if the data transfer is interrupted, only partial items are saved in the project file but it also releases the items that are not saved?
Possible solutions/workaround:
 When this happens, it looks like we can use the "cut and paste-in-place" function to re-checkout the items and commit the unsaved items again.
I don't think checking out the layer will check out symbols.
So if a window or door is a symbol in wall, they will need to be checked out separately if they occur on other layers that's not checked out.
The "custom check out" filter is hard to use if a particular layer has multiple symbols and trying to know which object to filter for which layer is difficult.
Usually, we just use the "custom check out" to filter out every object and check everything out.
Side note regarding the "custom check out" / criteria window:
There doesn't seem to be a way to remove the particular criteria without removing everything from the bottom up.
For example, if there are 5 criteria selected and then criteria 2 is no longer relevant, there is no way to remove it without removing criteria 3-5 first.
Also, there doesn't seem a way to reorganize the order of these criteria.
No, a "Save and Commit" action is an all or nothing action - either all your changes go in or nothing goes in.
You cannot check out resources. Multiple users can modify the same resource. The 2nd user to commit his/her change will be forced to resolve the conflict.
I think you are mixing symbols and symbol instances.  A symbol definition is a resource. It shows up in the Resource Manager. However, a symbol instance is an instance of a symbol definition.  You can insert a symbol instance into a wall. You can check out the symbol instance, but its check out status is different than that of another symbol instance.  As I mentioned above, you cannot check out a symbol definition.
I agree. We are working on a solution, and it would be available in a future version of Vectorworks.
I see. It may be a bug in this case then because we are sometimes getting only half of the items committed to the project file.
For example, lines and shapes would commit but not dimensions.
The dimensions would then be released so further commits would not pick up those dimensions.
Newly added objects and dimensions would commit but the old ones do not show up.
The workaround was to cut the uncommitted dimensions (thus checking it out again) and paste in place.
This allows these dimensions to be committed to the project file.
Ah okay, I'll have to try the offline mode again.
There was one question regarding the symbol definition conflict resolution pop up with the rename option grayed out.
Example:
There's a typical unit type symbol definition that occurs on multiple layers.
User 1 (working offline) checks out layer 1 and works on the symbol definition 1 at home.
User 2 (working online) checks out layer 2 and works on the symbol definition 1 at the office and saves and commits.
User 1 gets to the office and commits all changes to project file, there is a conflict pop up to either overwrite the symbol definition, leave it as is, or rename the symbol definition (somehow this option is grayed out).
You should not have multiple users deliberately edit the Symbol definitions as you've described. One of the users will always lose their changes.
Yes, this is the Conflict Resolution dialog. User 1 (being the 2nd user to commit) will be forced to either accept his changes to the Symbol definition or discard it. The Rename option will always be grayed out since you are not allowed to rename the symbol definition.
By the way, User 1 does not need to be offline to get the Conflict Resolution dialog.
Yeah, it is almost always by accident since there's no way to check out the symbol definitions as you mentioned.
So one user might be working on the unit symbol and another user accidentally access the symbol as well to make a quick change but has no way of knowing if another user has already edited the symbol until they do a save and commit.
It would be helpful if there's a rename or duplicate the symbol with another name option so both users can figure out what has changed between the 2 edits.
The conflict resolution dialog does appear for users online as well but usually, the problem happens when one user takes the file home to work on so they have no idea who is working on the symbol at the office.
This creates a problem when there are hundreds of symbol definitions and multiple people working on the file.
No one knows which one they are "allowed" to edit without a conflict dialog pop up during a save and commit.
Posted (edited)
Does anyone know how to disable project sharing on a file?
Edited by DKPD
File > Save A Copy As, and make sure the filetype is set to .vwx
Thank you, I was using Save as.... It won't show the other file types. Thanks!
sorry for reviving ...
how to access a project file located on the company's google drive? when i open a working file, there's no option other than local or connected drives...
thx
rob
Could you please elaborate?
Are you using Google Drive File Stream? Project Sharing is not compatible with Google File Stream.
Project Sharing is, however, compatible with Google Backup and Sync. You will need to install the Google Backup and Sync client on your machine. The client allows you to specify a folder on your local machine where your files are synced.
You can learn more about Project Sharing and how to set it up here:
Thanks,
Tolu
hi tolu,
thanks for looking at it.
no, just dropping files onto our google drive in the web browser.
i've set up my private cloud at home for this functionality, but now i have to do it for the company before i buy an additional nas drive 🙂
so the next step would be to install the google b&s client, but do i  have to do anything on the server side?
have fun,
rob
Edited by gester
No, you do not. You simply need to share the folder containing the PF with other users.
Each user (on their respective machine) will open the PF in their local Google B&S folder, and Vectorworks takes care of the rest.
Thanks,
Tolu
ok, i've installed and logged in.
now i want to choose my local folder for project sharing (which is in my user directory on the main drive of the computer) and select it for constant backup. what is wrong with it?
You cannot select a network folder as you Google B&S folder. You have to select a folder that resides on your machine.
Once you make changes, Google B&S will then B&S the file to Google's server. If you've shared the Google Drive folder with other users, their Google B&S client will then pull your changes from Google's server into their respective Google B&S folder.
the folder 'teamwork' resides on my machine, it's not a network folder. or am i missing something?
