I've been pulling my hair out for a couple of weeks- I'm trying to render the interior of a gallery- I've modelled the frames and figured out how to do the lighting (sort of) but for some reason however I do the renders the images inside the frames are not showing.
I've tried drawing a rectangle (set working plane) and then imported a jpg via the resources browser then applied it to surface and amended the dimensions to fit- looks great in open gl- but when rendered they are not showing.
I've wondered if it is perhaps because its a rectangle surface and not a solid so I have tried extruding it to make a solid and applying it as a texture but it is a tiled texture with repeats. When I untick the repeat I can't seem to get it in the centre or at the right scale.
Can anybody point me in the direction of where I'm going wrong? I've investigated using it as an image crop but I don't want it stay in a fixed position.
NCSMITH
Hello,
I'm using VW 2018- fundamentals and spotlight
Many thanks!
N
Edited by NCSMITHLink to comment
6 answers to this question
