CAN'T DRAW NEXT TO OBJECT
Hi there!
So I want to draw my lines next to an object but it won't show the dots on the corners like it used to do some weeks ago. Suddenly, it changed it all and wouldn't show them anymore and as result you can't draw good shapes. Also my layers are always in 1 layers, and the default class and layers are on (Class= 9, layers= 5) just like other students of my class and it works for them?! Even when I'm on it or select a cube for example. Here's the problem in pictures.
Thanks!
3 minutes ago, Jibbe D'hondt said:
This? I can't find the snapping option.
It is right below your attributes palette where it says snapping. You may want to stretch that palette a little to show other snapping options.
Edit: Jim just showed you where to find it.
Edited by Art V
