Phil hunt Posted November 17, 2017 Share Posted November 17, 2017 (edited) I have posted in 3d modeling I should know how to create this....but I am struggling to remember the solution......thanks all sub-d maybe Edited November 17, 2017 by Phil hunt wrong subject Quote Link to comment
EAlexander Posted November 17, 2017 Share Posted November 17, 2017 (edited) I would sweep a rectangle around a locus and offset the pitch of the sweep. Distance from profile to locus should be the Radius of your overall curve. The SEG field will let you adjust how many profiles are used to make the sweep - so you can adjust the "resolution" of the sweep. I believe this number changes based on what your 3d settings are : low, medium, high, very high - but you can dial in any number you want. Lower number= more profiles. Trim to fit as needed. Edited November 17, 2017 by EAlexander Quote Link to comment
Kevin McAllister Posted November 17, 2017 Share Posted November 17, 2017 I also think Sweep is the best solution here. You could create a Helix Spiral and then an Extrude Along Path, but it doesn't have the ease of adjustment of the Sweep.... Kevin Quote Link to comment
Phil hunt Posted November 17, 2017 Author Share Posted November 17, 2017 thanks, guys tweaking needed....but not far to go Quote Link to comment
Phil hunt Posted November 17, 2017 Author Share Posted November 17, 2017 now for applying the decals !!!!!! Quote Link to comment
