Wesley Burrows Posted November 16, 2017 Share Posted November 16, 2017 I have a 2018 sheet border/title block design that I made in my template file. I want to use this in an existing file. When I tried copying the sheet border from my template file and pasting it in place in my existing drawing, all of the data fields are reset to default, How do I correct this? I've tried purging sheet border special records, reseting plugin objects. Template File: Paste from Template File: Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted November 17, 2017 Vectorworks, Inc Employee Share Posted November 17, 2017 Hello Wesley, Do you have any other Title Block Borders in the file you are pasting your template TBB? If so, what option are you selecting on the Merge Formats dialog? Could you test this in SP-2, when it is released, and let me know if you are still reproducing it? Thanks, Nikolay Zhelyazkov Quote Link to comment
Wesley Burrows Posted November 17, 2017 Author Share Posted November 17, 2017 (edited) 6 hours ago, Nikolay Zhelyazkov said: Hello Wesley, Do you have any other Title Block Borders in the file you are pasting your template TBB? If so, what option are you selecting on the Merge Formats dialog? Could you test this in SP-2, when it is released, and let me know if you are still reproducing it? Thanks, Nikolay Zhelyazkov I don't think so. I also got no merge/replace dialog, so that leads me to believe that I didn't. I will test in SP2. Hopefully that means SP2 is appearing soon. =) Edited November 17, 2017 by Wesley Burrows Quote Link to comment
Vectorworks, Inc Employee Neil Barman Posted November 19, 2017 Vectorworks, Inc Employee Share Posted November 19, 2017 (edited) @Wesley BurrowsWhat happens when you import (rather than copying & pasting) the Title Block Border from the source file into your destination file via the Resource Manager? Edited November 19, 2017 by NeilB Quote Link to comment
Wesley Burrows Posted November 21, 2017 Author Share Posted November 21, 2017 (edited) On 11/17/2017 at 2:46 AM, Nikolay Zhelyazkov said: Do you have any other Title Block Borders in the file you are pasting your template TBB? I just tried this with a different file that did indeed have an old title block On 11/17/2017 at 2:46 AM, Nikolay Zhelyazkov said: what option are you selecting on the Merge Formats dialog? I was prompted with no merge/replace dialog of any kind. On 11/17/2017 at 9:36 AM, Wesley Burrows said: Could you test this in SP-2, when it is released, and let me know if you are still reproducing it? I just did this in SP2 and the problem remains. On 11/19/2017 at 5:43 PM, NeilB said: What happens when you import (rather than copying & pasting) the Title Block Border from the source file into your destination file via the Resource Manager? I also just tried this in SP2 and got the same result. Edited November 21, 2017 by Wesley Burrows quote failure Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted November 22, 2017 Vectorworks, Inc Employee Share Posted November 22, 2017 Hello Wesley, Could you please fill in a bug report with attached screen recording showing how to reproduce the bug and test file? Thanks, Nikolay Zhelyazkov Quote Link to comment
Wanyu Liang Posted April 10, 2025 Share Posted April 10, 2025 Ich verwende Vectorworks 2025 und habe das gleiche Problem Quote Link to comment
