James Russell Posted November 16, 2017 Share Posted November 16, 2017 Hi All, I'm going a little crazy and need someone to do this bug test for me, two parts; Part One Make a truss. Convert to lighting position. Using Instrument Insertion place a few lamps onto the truss. Raise Truss lighting position to 6000mm in Z. Ensure lights stay on truss from front view. Part Two Make a Truss. Convert to lighting position. Raise Truss lighting position to 6000mm in Z. Using Instrument Insertion place a few lamps onto the truss. Ensure lights are hung on truss (mine aren't!) *Optional extra - try to hang more lights on lighting positions, default insertion is 0mm. Just let me know if your experience is the same. Especially @JimWdo you get this? Hope you're all well. J Quote Link to comment
0 Wesley Burrows Posted November 16, 2017 Share Posted November 16, 2017 (edited) 15 hours ago, James Russell said: Part One Make a truss. Convert to lighting position. Using Instrument Insertion place a few lamps onto the truss. Raise Truss lighting position to 6000mm in Z. Ensure lights stay on truss from front view. Part One Result (with Truss PIO) x 15 hours ago, James Russell said: Part Two Make a Truss. Convert to lighting position. Raise Truss lighting position to 6000mm in Z. Using Instrument Insertion place a few lamps onto the truss. Ensure lights are hung on truss (mine aren't!) Part Two Result (with Truss PIO) Both ended up the same for me. (wrong, because of moving lights inside the truss) but attached. Unless you tried the fun party trick of selecting all of that position and moving it to a new design layer. Then you get this fanciness: Or if you delete the right two fixtures from the original and mirror the left two across the center line, then you get this: There are lots of issues with the 2018 (SP1 at the moment) hanging position. So I don't doubt you are getting strange results. Edited November 16, 2017 by Wesley Burrows updated Quote Link to comment
0 Wesley Burrows Posted November 16, 2017 Share Posted November 16, 2017 (edited) @JimW this might get a bit more response in the Spotlight section, or perhaps Troubleshooting. @BrandonSPPdo you know if any of the above has been addressed in the forthcoming SP2? -W Edited November 16, 2017 by Wesley Burrows Quote Link to comment
0 Guest Beckstorm Posted November 17, 2017 Share Posted November 17, 2017 Snapping to the center line is fixed in SP2, I will need to test the rest but I think we solved them as well. Quote Link to comment
0 Wesley Burrows Posted November 21, 2017 Share Posted November 21, 2017 On 11/17/2017 at 10:39 AM, BrandonSPP said: Snapping to the center line is fixed in SP2, I will need to test the rest but I think we solved them as well. I tested all of the above and confirm they seem to be solved in SP2 Quote Link to comment
James Russell
Hi All,
Part One
Part Two
J
4 answers to this question
