sta 500 Posted June 11, 2004 Share Posted June 11, 2004 hello am running g5 with 1gb ram and os x 10.3.4 all applications run fine including vw 10.5 having installed vw 11 everything still runs fine but vw runs at a snails pace any suggestions? Quote Link to comment
Guest Posted June 11, 2004 Share Posted June 11, 2004 Go to File>Preferences>VectorWorks Preferences. Under the display tab, do you have the last two options check marked? Quote Link to comment
sta 500 Posted June 11, 2004 Author Share Posted June 11, 2004 hello have checked this and still runs slowly with options checked and unchecked have now installed vw 11 on o.s. 9.1 g4 mac and is also running very slowly while other applications ok Quote Link to comment
Guest Posted June 11, 2004 Share Posted June 11, 2004 Leave those two options un-checked. Have you run disk permissions since you installed VW 11? Quote Link to comment
Guest Posted June 14, 2004 Share Posted June 14, 2004 You should run Disk Utility and verify and repair disk permissions. You will most likely find speed improvements after that. Quote Link to comment
siewertdesign Posted July 23, 2004 Share Posted July 23, 2004 I have found that if the 3D snap "snap to edge", is selected, it significantly slows down the application using viewports. Quote Link to comment
