mariush573 Posted November 8, 2017 Share Posted November 8, 2017 Hi, I am a student, currently working on a project and I am making some perspectival sections. I need to know how can i adjust the height of the horizon so that I will have the height at eye level. Thanks in advance And also is there any chance i can somehow turn on shadows with hidden line style? I know it's not possible using hidden line, but if there is any other solution i can get that effect of white cad drawing with shadows. Thanks PERSP SECTION.pdf Quote Link to comment
Matt Overton Posted November 8, 2017 Share Posted November 8, 2017 From what i can work out sections are single point perspectives and default to the middle point of section bounds. Two ways to change from memory. - Replace the crop object of the section with a rectangle centred were you want the vanishing point. - Adjust the top and bottom cut-off of the section so it's equal distance above or below. You can also adjust the perspective distance to show more or less of the receding walls. Quote Link to comment
mariush573 Posted November 10, 2017 Author Share Posted November 10, 2017 can you explain in detail what do you mean by " replace the crop object of the structure"? or adjust the top and bottom cut off? I really need to change the height level. Thanks Quote Link to comment
Diego - Resuelvector Posted November 26, 2017 Share Posted November 26, 2017 Whenever you have a viewport, you have the ability to crop it with a shape to get differents looks of the viewport, if you edit the crop of the viewport you could edit how the perspective looks. chek this video about viewportshttps://www.youtube.com/watch?v=yiD6lobdLJI Quote Link to comment
mike-h Posted November 28, 2017 Share Posted November 28, 2017 Hi its worth having a search particularly for issues/ requirements that you think others might share. A search for "vectorworks white card" turns up a lot of results, including http://www.vectorworks.net/training/2016/getting-started-guides/common/white-card-rendering Quote Link to comment
