LSWHEELDON
Fillet Tool Not Working Properly
I switched to fundamentals to do a video tutorial, and reset all preferences, just as the video suggested. However, when I try to use trim mode of the fillet tool on two adjacent (straight) edges of a polygon, the action is blocked  and a message at the lower right corner of the document says "the fillet tool can only be used on adjacent curves." I know this action used to work, I've used it many time. What is going on?
3 answers to this question
I was able to use the tool as you explained and expected in a test document, can you post your geometry in a test file here so that I can take a closer look?
Looks like these corners were already filleted, though I had to zoom far in to see it:
You'd need to delete the curved vertex in order to fillet that corner again.
