Marionette Node Object Text Label only visible in 2D view
Benny Franke
Hello,
this is my first post so please tell me if i did something wrong.
My problem ist as followed: i create an rectange extrude and put a textlabel on all the 6 sides of the dice. All this is done via Marionette nodes.
Once i create a wrapper it still works.
Once i create a Marionette Object I can't see the text objects in the 3D view anymore.
infos: the text objects are 6 groups i moved into place.
anyone an idea?
thanks for reading
Hello @Spotbenny-
I think this has to do with the difference between a Marionette Object and 3D geometry in Vectorworks - a Marionette Object acts like a hybrid symbol, so 2D objects have to be converted to 3D to display outside of Top/Plan. To do this, you can convert your text to polys and then convert those polys to 3D polys. I think that will work. There is a node in the Objects - Text folder called Convert to Poly Group, I believe.
Alternatively, and I don't know if this can be done in Marionette, would be to convert the object to Plane objects instead of Screen Plane objects. There is a Set Plane node in Marionette, but I don't have time to play with it right now.
There are also a number of ObjectVariables that control screen plane / layer plane, but again I don't know if those are directly accessible through Marionette and don't have time to check right now.
Hi @sbarrett , @Pat Stanford
thank you very much. that did work. now i have to arrange those labels slightly on top of the dice because they shimmer in openGL view. Is there a snap to surface node or something like this?
sorry for all the questions but i can't really find documentation for all the nodes there are.
I will definetly try the plane object thing later. Thanks for all the help.
