Attribute Palette issue
ZachCiaburri
For some reason my Attribute palette is just blank and gray. I've had this issue with the object palette before as well but luckily when using spotlight you can use the instrument insert tool to select your instrument. I have no clue how to fix this. I have restarted vectorworks numerous times, I have used different files. No matter what line or shape tool or even text tool I select there is no option for attributes.
3 answers to this question
