TItle Block - Pop-Up fields
DanT
Hi All,
I'm a new convert to VW and I'm going through the processes of setting up a host standard drawing elements for use in the future.
I've followed the guide for the custom title block creation (http://app-help.vectorworks.net/2017/eng/VW2017_Guide/Setup/Creating_a_Custom_Title_Block.htm) and for the most part it's working as expected.
I have a collection of P_ and S_ prefixes that are behaving. However, the pop-up fields are only showing up on the data tab of the object info palette. When I double click the title block the field that should be a pop-up is just a standard text field that I can populate freely.
Have I missed a trick? Is there some way to force the 'double click' edit of the title block to also show the pop-up fields that I defined in the record?
Many thanks,
Dan
