I've run in to this while trying to change wall textures by object or component for individual multiple viewports of a housing unit on a design layer.
1. As a test, I created two walls using the brick veneer-wood studs-sheetrock style on a base design layer.
2. Set one to overall texture by object class and the other to component texture by brick veneer class.
2. From the base layer, created two viewports on a composite design layer.
3. On the composite layer, on one viewport, changed the class texture settings for both the wall class and brick veneer component class to a different brick texture, use document settings button unchecked.
4. No change to viewport.
5. Changing the document settings for the same wall and component classes changed both viewports.
There are no class override buttons for the viewport on a design layer just a current document setting toggle. However, other class or layer visibility changes work. Placing the same viewports on a sheet layer does provide override options.
Allen Brown
Not sure if this is a bug or a feature..
walls.vwx
0 answers to this question
