Wesley Burrows Posted October 25, 2017 Share Posted October 25, 2017 (edited) Ok, I can't figure this out. I have an LED ticker/ribbon wall that's 1 panel high and 68 wide. Each panel is let's say 20#s. 20 X 68 = 1360#'s total for the wall. If I put 1360 in the Total Weight field, the math it does for distributed weight (8,155.94 lb/ft) makes absolutely no sense. What am I missing? I also don't understand why I can't put the per-panel weight in a field somewhere and then have it keep the math correct based on the total # of panels as changes and cuts happen. Edited October 25, 2017 by Wesley Burrows Quote Link to comment
Wesley Burrows Posted October 25, 2017 Author Share Posted October 25, 2017 To further clarify. If I put in a total weight shouldn't the lbs per foot be the total weight divided by the the total width of the LED object? So if the total LED wall weight was 1000 pounds and the wall is about 8 foot wide wouldn't it be 1000/8 = 125 pounds per foot? Instead if I put in a total weight of 1000lbs it shows the distributed weight as 3998.68 lb/ft. How could it possibly weigh more than its total weight when distributed on a pounds per foot basis? Quote Link to comment
Guest Beckstorm Posted October 25, 2017 Share Posted October 25, 2017 This looks to be a bug on the LED wall tool, I have submitted it to be fixed. A work around would be to use the Insert Load tool. Quote Link to comment
Mike Wright Posted October 26, 2017 Share Posted October 26, 2017 The LED screen tool is not compatible with braceworks in similar fashion to the line array tool. With the line array tool you can create your array then create a symbol from that array which can be used to replace the default point load symbol in braceworks. This DOES NOT work for distributed loads so the only LED screen workaround is to add a load separately from the screen itself. VW are aware of this, I'd expect it to be a feature of the non beta release when it comes...... Quote Link to comment
mikekow80 Posted October 27, 2017 Share Posted October 27, 2017 How did they not have these 2 tools compatible with their expensive add-on?! I just gave up on the audio point for now. I even drew a little truss with attached loads, but now the motors won't attach to the truss. Much like before SP1. It worked fine on 5 lighting trusses. Quote Link to comment
Mike Wright Posted October 27, 2017 Share Posted October 27, 2017 Your little truss might not attach because the geometry is not exactly lined up, copy and paste the value for the position from one to the other for the axis parallel to the truss, even this may not work, if so you might need to manually align the truss loci. Also it doesn't seem to like 'joining' trusses of different cross sections sometimes. Quote Link to comment
Guest Yordan Kostadinov Posted November 1, 2017 Share Posted November 1, 2017 The problem with the Weight of the LED Screen is fixed for the upcoming SP2. Quote Link to comment
Wesley Burrows Posted November 1, 2017 Author Share Posted November 1, 2017 1 minute ago, Yordan Kostadinov said: The problem with the Weight of the LED Screen is fixed for the upcoming SP2. Awesome, Thanks! Quote Link to comment
