tpenna Posted October 23, 2017 Share Posted October 23, 2017 I'm working in Spotlight inserting lighting symbols onto hang positions. Hang positions are at 22' elevation. Every light I insert goes to 0" elevation, then I have to change its Z value in OI palette. Is there a way to change the default Z click? Quote Link to comment
william7 Posted October 23, 2017 Share Posted October 23, 2017 Hi, I believe this is being caused by your hanging position not being recognized as a 'Lighting Position' After using the 'Lighting Pipe' tool you need to then covert that pipe or position in to a 'Lighting Position' To do this: Spotlight/Object Conversion/Convert to Light Position. This should allow for the fixture to adhere to the pipe and get the z height information. You can add the z height before or after the conversion process, through the Object Info. Palette/Shape tab. Quote Link to comment
