bobbayer Posted October 22, 2017 Share Posted October 22, 2017 I am trying to create sloped and flat and curved flor sections for an auditorium. Slab is flat only Quote Link to comment
RickR Posted October 24, 2017 Share Posted October 24, 2017 I've done surfaces. Loft some Curves and you can get a nice dished shape. Extrude to make a 3D if needed. Roofs make good sloped floors and ramps. 1 Quote Link to comment
bobbayer Posted October 26, 2017 Author Share Posted October 26, 2017 I have used multiple shapes and extruded but was not successful in adding that surface to the walls and creating walls that followed the floor elevation and floor that followed the wall perimeter ie... trimmed each other. I will tackle roofs next. Thanks Bob Quote Link to comment
mike m oz Posted October 26, 2017 Share Posted October 26, 2017 for the floor use Sweep or as Rick suggested Lofting and then Shelling to give it a thickness. If you use Fit Walls to Geometry the Walls should follow the floor you have modelled. 1 Quote Link to comment
bobbayer Posted October 26, 2017 Author Share Posted October 26, 2017 Oh Boy.... I have a lot to learn... (-: Never used either command. Will work on it now. Thanks for the guidance. Bob Quote Link to comment
Kevin McAllister Posted October 26, 2017 Share Posted October 26, 2017 If you post an image of what you're trying to achieve we may be able to give you more specific advice. Kevin Quote Link to comment
bobbayer Posted October 30, 2017 Author Share Posted October 30, 2017 I got it! I got it! Yippie Thanks guys Bob Quote Link to comment
AlanW Posted October 31, 2017 Share Posted October 31, 2017 @bobbayerhi you can draw a section through you floor and sweep that. Quote Link to comment
