Todd V. Posted October 19, 2017 Share Posted October 19, 2017 After upgrading to VW 2018 SP1 from VW2017, my text input in title block data records in VW2017 files displays as vertical rows of letters (see attached). Please advise. Screen Shot 2017-10-19 at 19.08.25.pdf Quote Link to comment
Art V Posted October 20, 2017 Share Posted October 20, 2017 You may want to check in your title block if the text "box" of your record has been reduced in width as that would be the most likely cause for this at first sight. Another option that could work is to go into edit mode, change the text size to something different and then back to the size it should be as I have an issue with symbols sometimes where text gets squeezed in the display (and output) for no apparent reason, going into edit mode change and change back the text size solves it. It might work for your title block issue as well is the text box is not the issue. Quote Link to comment
