Braceworks truss converted to Hanging Position: how to "select system objects?"
SCParker
After placing a bunch o truss and then converting them into a hanging position, how may I then "select system objects" of all the truss, motors, and stuff hanging from the truss?
If I do not convert to a hanging position, I have the "select system objects" button in the OIP.
I want to be able to select to confirm that all the gear that is needed to be part of the system is actually part of the system.
The only way I can do this seems to be to double click the hanging position and then click on a truss section, then exit the hanging position and see that the system has remained selected. Seems dodgy to me.
Thanks, Scott
Guest Yordan Kostadinov
Hello Scott,
In the upcoming Vectorworks 2018 SP2 you'll be able to find the "Select System Objects" OIP button for the Hanging Position as well.
Regards,
Yordan
